| High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. |
08-28-2009, 09:23 PM
muffler+drill=??
ok so i got an engine kit,installed it, and it seemed sick...witch in my eyes was normal because im 250 pounds...but i lost the cap off the end of the muffler what all xactly fell out is unknow to me...but i took a drill bit about 2 sizes smaller than a 1/4" drill bit...i drill 2 holes in the round peice,with the bolt welded on, that if i am correct is the catalac-coverter??i drill these 2 holes and got a big improvement in the stock muffler....but remeber i dont have thebottom cover on the muffler..and the bit size is 2 shades smaller than 1/4"
08-29-2009, 10:31 AM
Custom Builder / Dealer
Re: muffler+drill=??
Yep... you made the pipe flow a little better. (it's a very easy way to gain power!!)
08-29-2009, 01:17 PM
i rode it a little bit today...it runs great now, not much smoke and much more power
08-30-2009, 04:50 PM
Lots more noise to huh?
Motorized bicyclist
08-30-2009, 11:51 PM
do you have pics?
10-29-2009, 07:04 PM
i want to see pics
10-29-2009, 07:18 PM
a guy who makes cool bikes
i kinda did the same thing, but i don't have pics, either.
if you take the screw out of the bottom, the cap pulls out with a pipe welded to it. i drilled 5 or six little holes thru the pipe, so it looks like a flute i also drilled a few 1/4 holes in the end cap. installed it all back together, and used a pair of vice grips to tighten up the bottom screw.
it's actually QUIETER than stock, and it got rid of some of that ting ting tinny sound.
seems faster, too.
10-29-2009, 07:44 PM
With the Raw kits, you can just remove the exaust pipe end cap, & saw off the inside of the stinger tube & put it back on!! (still quiet, & lots of power!!!)
10-30-2009, 11:15 PM
I drilled a 1/4 inch hole in the end of the tube that has the bolt welded to it. pretty happy with the results: Good: top end increased significantly, higher revs and more speed, pulls hills a lot easier and faster. Bad: seem to have lost the bottom end... gutless on take off. I'd rather go faster once I'm going, so I'm fine with it.
10-31-2009, 03:21 AM
I respect that it's an easy and cheap (read "free" lol) modification, I even did it myself heh, but TBH it is just a work-around, yer not really "gaining" any power - yer just allowing the engine to breath a little better, allowing it to use the power it does have.
That's fine of course - but if you really want yer motor to not only run better but to get an actual gain in performance above stock - try the expansion chamber from Sick Bike Parts: Sick Bike Parts expansion chamber kit
Granted - it's not free lol, but it's worth every penny
| Thread Tools |
| Display Modes |
Linear Mode
