Old 08-28-2009, 08:08 PM
Buddy Buddy is offline
Default Manic Mechanic sprocket adapter
Does anyone here use the MM sprocket adapter? Is it better than the rag joint? How did you measure hub diameter? Every time I try to use calipers to get the hub diameter I get a different reading.
Old 08-28-2009, 09:38 PM
skjjoe's Avatar
skjjoe skjjoe is offline
Default Re: Manic Mechanic sprocket adapter
what bike you using
stay thirsty my friends
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
It is the best after market part you can get bar none.Call jim and he will help you on your readings.HD
You never know what you might know,you know
Old 08-28-2009, 11:01 PM
The bike is a Triax from Target. I had to get a different rear wheel becase the hub on the Triax tapered.
I've talked to Jim a few times. He just said to use calipers, which I've done, that's what I keep getting different readings with.
Old 08-29-2009, 01:17 AM
skjjoe's Avatar
the wheel wont work with the tapered hub .not worth his time to set up his stuff. to accommodate the hub adapter. only way i know is to get i new hub. or wheel.there is alot of the thee mile island hubs coming out of target now.
Old 08-29-2009, 03:10 AM
I already got a different wheel/hub.
Old 08-29-2009, 10:19 AM
drob drob is offline
Buddy, the best thing to do would be to take the rear wheel to your local hardware store or bike shop and have them measure the hub with a micrometer. Some of them even have the newer electronic models that will show the diameter in millimeters and inches. You won't be charged either!
Old 08-29-2009, 01:42 PM
I was thinking I needed to do something like that. Hardware stores have micrometers?
I was thinking a machine shop. I don't know if they would charge me or not.
Old 08-29-2009, 04:49 PM
HoughMade's Avatar
HoughMade HoughMade is offline
6" digital caliper- $12.99...and you will wonder how you ever got along without one.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 08-29-2009, 06:29 PM
That's what I've been using. I keep getting a different reading every time though. It doesn't help that the battery is about dead I think and the display is dim and flashing constantly. They aren't mine, mine aren't accurate enough.
