Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Motorized Tandems, Trikes and Recumbents
Motorized Tandems, Trikes and Recumbents Motorized trikes (tricycle) and recumbent bicycles can give the ultimate in comfort for cruising on long trips or just around town plus they will really turn some heads.
Old 08-28-2009, 03:37 PM
vooodooou vooodooou is offline
Default put a 49cc on this?
i wonder if they would let you run this on the street. lol with a 49cc engine it would be nice enclosed. take the heat off the exhaust to heat it. humm add peddles, enclosed trike
Blue Sky Design - products
Old 08-28-2009, 08:04 PM
myocardia myocardia is offline
Default Re: put a 49cc on this?
I can pretty much assure you that you would have to license and insure it as a NeV, if not a full-fledged motorcycle. Shoot, any engine that will go 40 MPH on a "normal" bicycle would have that thing above 60 MPH, since the majority of power that's required for bicycles is just to overcome drag/wind resistance. With that thing, there's almost no drag. Actually, the drag coefficient would be exactly 1/10th of a bicycle, so it would only require 1/10th the power for the same speed, compared to a bicycle. If I had the money, I'd buy a full setup, then put a fairly powerful electric motor on the rear wheel.
Robert
The best solar, wind, EV, and alt energy forum on Earth
This space under construction, which may be why I'm half a bubble off plumb.
Old 08-28-2009, 11:54 PM
they race those. the record is 60+ mph for 60 minutes with 2 33 ah batters at 24 volts. can you say 300 mpg at 49cc
Old 08-29-2009, 11:05 AM
wheelbender6's Avatar
I think it would be legal in AZ, IF you hold the speed below 20mph and have working pedals. I wish the site showed pics of the frame w/o the bodywork. It would make it easier to plan a build.
Old 08-29-2009, 01:27 PM
they had pics on there site in the past. frame is a rectangle with two arms off the back to hold the rear wheel, and two axles of pipe coming off both sides to hold front wheel and a single hoop roll cage with two braces going forward. very basic i think it was 1.5x1" box tube.
Old 08-31-2009, 09:51 PM
check this out
YouTube - Electrathon World Record at Bonneville
Wonder what the 49cc world record is?
Old 08-31-2009, 11:28 PM
It would have to be much faster, since battery weight really slows EV's down, compared to ICE engined vehicles.
Robert
