Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 05-20-2008, 06:20 PM
smokinbenrage's Avatar
smokinbenrage smokinbenrage is offline
Default Mounting the clutch handle
Where is the proper location on the left handle bar to mount the clutch handle? When I mounted mine, I cannot pull it back to lock it into place without hitting the bar. I ended up mounting it on the end of the bar so that it has enough clearance to operate properly. Is there some kind of extension that I can install to allow enough clearance between the clutch handle and the bar?
Please Help!!!!
Old 05-20-2008, 06:44 PM
Ilikeabikea's Avatar
Default Re: Mounting the clutch handle
Can you take a picture. It sounds like its bent. I didn't have that kind of trouble with either of mine.....................
Old 05-20-2008, 07:24 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Grind a little bit off of the tip of the locking lever... (just enough to allow it to click into the little locking notches.)
I've had to do this to every one of these levers so far!
The levers with a "push button" have never given me a problem.
Old 05-20-2008, 10:21 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I tossed mine and went to a brake lever it doesn't lock but I never had any real need to lock it that I couldn't slip a bit of inner tube over th brake handle.
Old 05-21-2008, 09:23 AM
Pablo's Avatar
Pablo Pablo is offline
Something doesn't sound right. My stock clutch handle locks 1/2 way in....either the clutch isn't adjusted right or you have a different animal....Indeed, pic please.
