Old 08-26-2009, 04:27 PM
Dylanpieper Dylanpieper is offline
Default Help [Detailed pics]
Continue from last question i got a lot more pics for you to trouble shoot a ****'a lot easier.
Order / Setup of my throttle
(Still don't snap back to idle) (took out big lump):
ImageShack Gallery
Clutch Pulled and Original:
ORIG - Imageshack - dscf0084x
PULL - http://img218.imageshack.us/i/dscf0085qmb.jpg/
Also to through this out their...My throttle doesn't feel smooth, nor secure..Its made out of plastic inside.. Just to through out their
Old 08-26-2009, 05:28 PM
restapukin restapukin is offline
Default Re: Help [Detailed pics]
man, i fear the guys will find the photos to be too blurred .... get more light on the stuff and you get wider focus.....
Old 08-26-2009, 05:36 PM
but the clutch problem looks simple.... you got one more cable-bracing move to make, down below
it's easy... i won't spoil it for you
Old 08-26-2009, 05:39 PM
Im a big fan of spoilers!!!!! PLZZZ HELP I NEED THIS TO GET TO SCHOOL MORE OF A RUSH THEN A GAME!!!!!!!
Old 08-26-2009, 06:15 PM
dvddtz's Avatar
dvddtz dvddtz is offline
The clutch cable has to go through the cable stay under the carb first,and then hook it to the actuator.And the nub you removed from the throtle is supposed to keep the throtle from spinning on the handle bar.It fits in the hole you have to drill.
Old 08-26-2009, 06:20 PM
so the grip is only suppose to move? cause that plastic thing pulls back witch pulls back the wire
Old 08-26-2009, 06:35 PM
-- Thats what i did....
Old 08-26-2009, 06:45 PM
dvddtz's Avatar
Not according to the picture. Its supposed to go from the handle bars,through the cable stay then hook to the actuator Page Title look at the pic of the clutch cable
Old 08-26-2009, 07:43 PM
TYVM it works now i just need throttle and i can try to start her up!!!! VROOM! btw i only have 1 support on it..Should i be sturdy?
Old 08-26-2009, 07:50 PM
dvddtz's Avatar
If you mean only one motor mount,no,do not run it with only one motor mount.I doubt you would make it ten feet.
