Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 05-19-2008, 06:33 PM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
Smile A diffrent drummer
I found a 24" Schwinn mans bike & cut the tubes 2'' behind the seat post and
made the frame 25'' longer. Had to remove the top tubes & re-weld them. The
angle on the top tubes did not line up. I used new tube for all of it. It was not
easy but it went together well. Thanks to my welder friend Butch Mounted a steel plate drilled & mounted a HONDA 4.5 horse edger motor to it. Used an old clutch from a mini bike also the throttle. Still need a sprocket, and a chain guard I can make that. I used Bondo ( car body filler) to mold in the welds. It looks nice. May need a 26" rear wheel frame sits kinda low. The peddles clear the ground by 3". I don't think thats enough. Going to have to make the drive chains as they are not near long enough. I'm using the little white basket that came w/the bike for emptys
Old 05-19-2008, 06:41 PM
Bikeguy Joe's Avatar
Default Re: A diffrent drummer
Photos? Photos!
Old 05-19-2008, 07:35 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I found that a crank set from a child's 20 gets the pedals up and down. In other words the pedal arms are shorter. Give you more clearance without hardly any work. Those kid's bikes are everywhere.
Old 05-19-2008, 07:49 PM
nogoodnic's Avatar
nogoodnic nogoodnic is offline
Pictures please. This bike sounds really cool can't wait to see it...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
