Old 08-18-2009, 08:52 AM
ylionb ylionb is offline
Unhappy troubleshooting 80cc (bikeberry)
installed it fine but when i ride downhill & let out the clutch it starts & then stops when i reach level ground.I have already played with the choke & fuel intake & the screw next to the primer.
Old 08-18-2009, 09:16 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: troubleshooting 80cc (bikeberry)
Are you sure its actually firing up? or are you just hearing the engine spinning around from going down hill?
How are you mixing the gas?
did you check for spark?
Old 08-18-2009, 09:29 AM
its sparking.i started mixing at12to1 but added more when i saw it wasnt going.how can i tell if its realy going ? when i give it gas it makes more noise.
Old 08-18-2009, 11:53 AM
Sydneysider's Avatar
Sydneysider Sydneysider is offline
12:1?? woah man thats way way way too much oil.. if its a new motor should be running atleast 18:1. When you hear it start pull the clutch lever and give it a little bit of gas and it should keep running without stalling..
"....dunno what I did to my engine the other day but now my rear tyre wears out real quickly..."
Old 08-18-2009, 01:25 PM
like i noted since then i added more gas.
Old 08-18-2009, 01:48 PM
Is the choke lever down?
