Old 08-14-2009, 12:22 PM
Pitchfork311's Avatar
Pitchfork311 Pitchfork311 is offline
Default Smaller Intake Needed
Any one have an idea where I can get a smaller intake?
Old 08-14-2009, 12:30 PM
wheelbender6's Avatar
Default Re: Smaller Intake Needed
The intake at Manic Mechanic looks shorter, but check with them.
You can shorten your intake by cutting out a section and then connecting the
two pieces with a heater hose. There are several more complicated solutions posted on the site.
China girl in a 1976 Western Flyer
Old 08-14-2009, 03:22 PM
Ya I have one of manics intakes. With my New reed valve mod and my cns carb, I cannot use his. I cut it even shorter, but my new cards bowl sticks down lower than stock, contacts clutch.
I was looking for more of a shorter stock one, I like the citting and using a hose idea. But I found one that will proly work. Its a intake that instead of going up, it turns out and puts the carb just outside of frame, above the gear box. Should work out perfect. Ill post a pic when I get a chance.
