Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 08-14-2009, 10:46 AM
fakeplay's Avatar
fakeplay fakeplay is offline
Default gas milage
I have 66cc and I don't get no 100 mpg. I filled my tank to the top and went about 10 miles in all.
Now I'm at half a tank. Do the 66cc use more gas ? I weigh 240 lbs.
Old 08-14-2009, 10:57 AM
fm2200 fm2200 is offline
Default Re: gas milage
It has a lot to do with how high the engine revs, rear sprocket size, the levelness of your surroundings, hills consume much more gas, the greater the speed, less mpg. And the weight of the ride, which you already mention. I weigh 180 and have a 40T sprocket and live in a fairly level place, with some hills. I ride to the local stores and other places about a 5 mile round trip. I get around 65 to 70 mpg. I rarely go over 30mph.
Old 08-14-2009, 02:42 PM
fakeplay's Avatar
Thanks. Do they sell a 1 gallon tank ?
Old 08-14-2009, 03:02 PM
Cabinfever1977's Avatar
well im at 120lbs and have a 48cc with a 44t sprocket and ride on mainly flat ground,
im getting around 180-200mpg. i travel at speeds between 20-25mph crusing to go to the store and up to 30-32mph when i just want to go for a ride down some back roads.
i am using around 20:1 gas/oil ratio,was using 16:1 for breakin. i have around 500miles on engine. and im using all stock parts with no mods.
48cc dualstart Starfire GT-2 Grubee 44T Swchinn Delmar Cruiser + dual rear saddle baskets with 18v front and rear lights with rechargable battery
yes they do sell 1gal tanks,but you should get more than your 40mpg that you are getting now.
Old 08-16-2009, 01:18 PM
Fishermanblues's Avatar
Fishermanblues Fishermanblues is offline
Another thing to remember is that these engines use a lot more gas while they are breaking in. After using a couple tanks of gas your mileage will improve quite a bit.
Good luck,
Andrew
Old 08-16-2009, 03:22 PM
fakeplay's Avatar
Thanks, tell me more about the 1 gallon tanks and where to get them please.
Old 08-17-2009, 10:14 PM
just google 1 gal fuel tanks for dirt bikes.
Old 09-14-2009, 11:51 AM
Prasinos's Avatar
Prasinos Prasinos is offline
I had a broken in 50cc with a 36 tooth sprocket and i was getting 158 mpg of gas(oil added not included) I am now breaking in a 80cc and will let you know how the mileage changes.
Old 09-14-2009, 12:46 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Good luck,
Andrew
Very true, on my last tank full I got exactly 46 miles before I ran out and I get 3 tanks per gallon so that adds up to 138 MPG. Biggest thing is how you ride, running around at WOT you're going to get a lot worse mileage then just cruising. On the 46 mile ride, according to my spedo, I averaged 19 mph with a top speed of 32 and that was downhill with the clutch in and tucked.
Took a couple of rides this weekend and after just 12 miles I was over half empty but that was a little different, top speed of 33.8 downhill not tucked and the throttle wide open, did quite a few downhill rides like that.
