Old 08-13-2009, 01:21 PM
GYPSY GYPSY is offline
Default Belt Drive
The only belt drives I have seen are either a rear mount or manufatured Whizzer style set up. Are there any kits available to do a belt install similar to the Whizzer on a Schwinn Point Beach?
Thanks,
Gypsy
Old 08-13-2009, 02:14 PM
NEAT TIMES's Avatar
NEAT TIMES NEAT TIMES is offline
Default Re: Belt Drive
Gyspy, Welcome To The Forum. I Think "quenton" Is A Whizzer Dealer/expert And Has A New IN Frame Belt Drive Kit For Sale. Ron
PUMP YOUR BRAKES HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
Old 08-13-2009, 09:40 PM
ocscully ocscully is offline
The EZ Motorbike kit does use a v-belt for its primary reduction drive and then switches to chain for the final drive to the rear wheel. The output from the primary reduction can be changed from a sprocket to a pulley and then a Whizzer sheave can be mounted to the rear wheel to give you a totally v-belt driven drive train, but I believe that you need to source the small pulley and sheave yourself. But being as Quenton is into Whizzer in a big way he probably has everything you need. This change will probably add $150.00+- to the price of the already $650.00 kit though. I bet it would be a great set-up if the costs are not a problem for you.
ocscully
