Old 08-11-2009, 12:11 AM
helenmax112233 helenmax112233 is offline
Smile Mysterious engine problem
Anyone who knows what happen on my engine?
Today when I was riding my bike and the engine started to seize up so I took it back to the house. I took the engine apart and examined everything to find no problem so I rebuilt the engine. Afterwards the seizing problem consisted.
Could anyone help?
Thanks in advance.
Old 08-11-2009, 09:34 AM
Bikeguy Joe's Avatar
Default Re: Mysterious engine problem
How do you know it was seizing up?
How far down did you take the engine?
When you say "rebuilt" I am guessing you meant "re-assembled".
Old 08-11-2009, 11:27 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
My first question would be, How much oil are you mixing into the gas??? & are you shaking it well before you pour it into the tank??
Old 08-12-2009, 01:00 PM
broHSI broHSI is offline
Taking your engine apart before you contact your seller can invalidate your warranty
You bought your motor kit from TheLAShop.com so what did they
say about your problem?
Did you talk to them on the phone or by email? What kind of support do they offer?
What is their warranty?
Did you install the kit yourself?
Could anyone help?
Thanks in advance.
Old 08-12-2009, 08:48 PM
Qdot Qdot is offline
How loose is your chain? If your chain is too loose it will bunch up inside the casing. Thats my only thought on it.
Old 08-18-2009, 05:54 AM
Question Re: Mysterious engine problem
Finally find my thread here. Thank you for all of you trying to solve my problem.
My husband and I followed the instructions that TheLAShop.com sent to us to install the engine kit. It looked very cool after we finished assembling. We used a ratio of 20:1 gas mixture to run the motor. My husband said that oil ratio would be plenty of lubrication and the motor should not be seizing up with that mixture. The oil and gas were mixed in a gas can prior to being put into the gas tank and they were well mixed.
The motor barely ran and after about 30 seconds the compression got tighter and tighter until it sized up. And then we had to run the engine backwards to get it unstuck.
The bicycle motor is new to our lives. So we don't know much abut it.
Old 08-18-2009, 10:34 AM
It doesn't sound right that the piston would seize up that quickly if you had that much oil in the gas...
If you're right, and the engine did indeed seize up; I'm guessing that it's a bearing.
Do a few little tests... First- Pull the clutch lever in & see if the bike still rolls freely. If it does roll, I think the clutch & rear bearings are fine.
Second test- Take out the spark plug, leave the clutch lever "out" & roll the bike around & see if the engine is spinning freely? (is the piston going up & down?)
Tell me what you find?
Old 08-19-2009, 08:07 AM
Sounds like a warranty return issue.
Old 08-23-2009, 11:32 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
they rolled or ran it backwards to get it unstuck? sounds like the chain is bunching up on the front sprocket? If that is the case then your drive chain is too slack. Just a guess.
Norman
norms-iron-works.tripod.com
Old 09-15-2009, 10:45 PM
Hi guys,
Thanks for all your advice. I couldn't do anything to the motor and, I didn't know how to deal with it either. I finally asked the seller - TheLAShop.com - Tattoo Kit - Bicycle Motor - Massage Equipment - Gardening Equipment - Heat Press Machine - Photography Equipment - Aquarium Supplies - & Much More! for help. They tried many ways to help me solve the problem, however, none worked. At last, they sent me a new motor while I had to return mine for exchange. Anyway, I feel their customer service is good, nice with patience. And so far, the new motor runs well though I am still curious to know what happen to my former motor.
