Intake & ExhaustThe ins and outs - carburetors, manifolds, mufflers, expansion chambers and more
to keep your motorized bicycle running the way you like
I was wondering what everyone was using to seal the oil leaks with this exhaust.
Is there a high temp paste to use or are you expected ( once fitted up ) to weld the pieces together ?
Thanks Ghost0, I saw that but was trying to figure out a little cleaner looking solution.
When I got my kits, both had a copper piece mounted to the manifold with some kind of paste and I was wondering what that was.
We used an exhaust sealing material there but it only works on that joint because it is a press fit and is only intended as a seal. The gaps on the other joints are too large and exposed to too much vibration for that material to work. I agree the tubing is not the most elegant solution but it works and it is what makes our pipe so universal in its mounting options.
