Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycle engine
Old 08-07-2009, 11:54 AM
joeblow's Avatar
joeblow joeblow is offline
Default head gasket trouble
I took the top off my engine to check the spark plug's flushness, and since I put it back on it has been sputtering out a small amount of fuel when it runs. is there a specific way to put the head gasket on? it seems to be a square. It is slightly indented on one side, presumably from being installed, does this need to be up or down?
Old 08-07-2009, 12:02 PM
Finfan's Avatar
Finfan Finfan is offline
Default Re: head gasket trouble
Head gaskets generally should be replaced when you open up a used engine. You could try some head gasket sealer and see if that helps.
Edit: You should also be sure you torqued the bolts evenly when you put it back! Otherwise you can warp the head!
-and-
I'm not lost, I'm exploring!
Old 08-07-2009, 01:05 PM
Bikeguy Joe's Avatar
Where is the fuel sputtering from? If you re-install the head gasket the same way it came out, it will usually be fine.
Old 08-07-2009, 09:53 PM
Mike Hunt Mike Hunt is offline
im having the same problem, when i start it i can sometimes feel a bit of air blowing from a corner of the headgasket, but after 30 seconds or so it stops. the bike still runs reasonably well though. i think one of my headbolts is stripped.
it was a lot worse before, but i took off the cylinder head and used some rtv sealant, but theres is still a small leak, after every ride i get a few drops of the gas coming out through a corner of the headgasket.
does anyone know of a surefire fix?
Old 08-08-2009, 06:33 AM
Yes, replace the broken stud and install a new head gasket.
Old 08-08-2009, 08:23 AM
Pablo's Avatar
Pablo Pablo is offline
Agree with Joe, brief steps:
1) Remove head and lap sand (wet/dry paper on glass)
2) Replace studs
3) Install new head gasket, and torque appropriately
Old 08-09-2009, 06:53 PM
roxrcool roxrcool is offline
I just put together a motor from a couple of busted up motors. put in a new base gasket
(dry, no sealant) and a new head gasket. both motors would roll just fine pushing it with
the clutch out. As soon as I mounted the motor, I knew it would fire right up. compression
was great. All I did was use some scotch-brite to clean up the base and the head, and
there is not a single drop of anything leaking. I think the sealer is what is causing the problems
that people are experiencing; or maybe just too much sealant. just my two cents so happy
to be back on my motor bike after a month or two with it being down.
Old 08-09-2009, 07:14 PM
ratty ratty is offline
I have used this on head gaskets several time with success, should be available at most auto parts stores. I used it in many different automotive applications, so I would think it should be great for these little Chinese motors.
http://www.permatex.com/products/Aut...ve_Sealant.htm
Old 08-09-2009, 07:16 PM
Pablo's Avatar
Neat stuff. I have successfully used Aluminum filled spray paint with no issues.
Old 08-09-2009, 07:20 PM
Pablo, I have wondered many a time if it were not just thick gold spray paint!!
