Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 05-15-2008, 11:35 PM
onesikschwinn's Avatar
onesikschwinn onesikschwinn is offline
Default big bore kit?
does anyone know if theres a big bore kit that will work for these engines?
Old 05-16-2008, 10:57 AM
paul's Avatar
paul paul is offline
Administrator
Default Re: big bore kit?
from my understanding the bicycle motor has a lining that makes it next to impossible to bore out the cylinder
Old 05-16-2008, 11:32 AM
oh really? i was riding my bike and its quick but i want more speed!!!
Old 05-16-2008, 11:53 AM
Ilikeabikea's Avatar
Norman (aka Lord Vader) discovered when he tore his engine down that his wrist pin bushing was drilled off center which essentially made the stroke a little longer than stock. His bicycle will fly. So that might be something you could try.......................
Old 05-18-2008, 08:19 AM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
I think I remember someone doing something similar regarding austin 7 based racing which I found on some site which was basically a write up of archive from the '60s. The motor concerned is a 10hp rated 747cc side valve (or in americanese, flathead) 4 cylinder.
The only problem was if the drilling was too off centre things parted company and large clouds of smoke and much havoc ensued.
There was also an unusual review of an old (1911 or so) racing car with a huge motor and an exhaust twist. There was a remotely operated valve half way between the manifold and the primary silencer that opened the exhaust to atmosphere when it was operated and apparently gave a useful hike in power.. something for the 4-strokers to ponder maybe?
jemma xx
Old 05-18-2008, 08:32 AM
Bikeguy Joe's Avatar
Smaller rear sprocket=More speed.
You can also open up your exhaust (cut or remove the baffle) clean up the intake and exhaust ports, install a thinner base gasket and a lot of other things for a little more power.
More power=less reliability, though when done right, I think you could get a modest power boost without too much sacrifice.
Also remember when making "adjustments" to a two stroke bicycle motor, to keep an eye on the jetting so you don't fry the engine.
Old 05-18-2008, 09:27 AM
Pablo's Avatar
Pablo Pablo is online now
I would start with the basics and clean up the intake and exhausts ports, but even easier, get a tuned exhaust and also simply clean up and match the intake manifold.
Old 05-26-2008, 03:18 PM
Goat Herder's Avatar
Gutter Rider
what about a steel bore sleeve frome another brand engine?
