Old 08-05-2009, 06:39 AM
Coval_PL's Avatar
Coval_PL Coval_PL is offline
Question Gas tank temperature
I have to ride my bike to work, and only safe place to leave my bike there is very sunny. Isn't it dangerous to leave black gas tank full of gas on the sun for couple of hours? Should I cover it by something blocking sun?
Old 08-05-2009, 07:35 AM
midatlanticcycle midatlanticcycle is offline
Default Re: Gas tank tempereture
it will be safe but a white cover/towel is excellent idea. make sure the vent is open on the tank cap. i've seen a few of the factory caps with the vent obscured. no vent means bigtime tank pressure build up and either flooding/starvation of fuel to the carb
Old 08-05-2009, 08:01 AM
Coval_PL's Avatar
Vent? I'm sure there is some spring inside the cap, but i'n not sure if this is the vent or close mechanism only. I have to check it. I think there should be some pressure protection, but i'm not sure, that's why I've asked.
Old 08-05-2009, 08:24 AM
jared8783's Avatar
jared8783 jared8783 is offline
Default Respuesta: Gas tank tempereture
there should be a very small hole in the top of the lid that is 24/7 open. it should be size of about pencil lead (graphite) or smaller
Old 08-05-2009, 08:38 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: Gas tank temperature
The gas WILL NOT explode from being in the sun!!! It takes a spark to ignite it.
I was watching some show, & a motorcycle cop was talking about how when they ride the bikes in a parade, the engine heat will make the gas in the tank boil!!!
Old 08-05-2009, 08:49 AM
Coval_PL's Avatar
Default Re: Respuesta: Gas tank tempereture
Yhanks I'll see. So if there is this vent, covering tank isn't necessary?
Old 08-05-2009, 09:10 AM
HoughMade's Avatar
HoughMade HoughMade is offline
I wouldn't worry about it. How many self destructing black motorcycles have you seen?
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 08-05-2009, 05:23 PM
Junster's Avatar
Junster Junster is offline
If you get a little fuel residue on the top of tank from riding with it full then you know it's venting.
Put something FUN between your legs..
Old 08-06-2009, 01:59 AM
Coval_PL's Avatar
I checked the tank cap, and there are four little holes on the bottom of cap so this is the pressure protection. Thanks.
Old 08-13-2009, 07:16 AM
jared8783's Avatar
You know now that I think of it a vent on the tank is not important in regards to flamability. And technically speaking your fuel will expand and become closer to a vaporous state the warmer it is. Meaning your fuel is more efficient when it is at higher temps. So while I wouldn't encourage the heat I wouldn't discourage it either.
