View Poll Results: what type of bicycle engine do you have
2 stroke bicycle engine 172 85.15%
4 stroke bicycle engine 28 13.86%
electric bicycle motor 2 0.99%
Voters: 202. You may not vote on this poll
Old 05-15-2008, 08:56 AM
paul's Avatar
paul paul is offline
Administrator
Default Bicycle Engine
gonna try a little pole on what types of bicycle engines most of you have. if you have more then one type choose whichever one you use the most. just click on the box above to make your choice
Old 05-15-2008, 06:54 PM
Bikeguy Joe's Avatar
Default Re: Bicycle Engine
Come on deacon, we know you are out there!
Old 05-16-2008, 10:18 AM
paul's Avatar
Administrator
looks like 2 strokes way out in front. after you vote you can see the results.
Old 06-11-2008, 09:06 PM
billyjoebigdaddy billyjoebigdaddy is offline
2 strokes are much easier to use than four strokes. No large crank case for oil and they are much lighter. I would not use any other kind.. besides 2 strokes are much cheaper as well.
Old 06-16-2008, 04:40 PM
FileStyle's Avatar
as Roscoe P Coletrain says " kk- I love it , I love it " my little 2 stroke
FileStyleCycles
Old 06-16-2008, 09:01 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I have the two stroke china girl... the two stroke weed eater and my ebike engine in a box since I used the frame for the weed eater. I have a bike to put the ebike stuff on but I'm holding off I have bid on a chainsaw motor. If I get it I am going to try to rig it direct to a sprocket from a china kit.
Any comments or ideas would be helpful..
Old 06-16-2008, 11:18 PM
thatsdax thatsdax is offline
The 2 strokes are lighter by a few pounds and can mount more easy between the crank for a better center of Gravity and cost less and have a life of 1000-6000 miles depending on how you treat them.
The 4 stroke is much smoother, much quieter, and the 4 stroke 48cc Titan will run with and even out run the 70cc 2 strokes. So when you consider the 50cc Titan with the 70cc Dax 2 stroke, the weight is pretty close. Also, when the life of the 2 stroke is nearing its end, the 4 stroke Titan is just getting broken in.Also since the 4 stroke mounts behind you, it allows you to install on a full suspension bike and makes for a super smooth ride, and it is even more quiet to ride with the motor back there, and there is nothing intrusive on the top bar or between your legs. Also.. The Titan 4 stroke is an automatic making for twist and go operation. Also, it makes better torque. Also, the Titan rear mount will allow you to mount to a step through frame making for easy mount and dismounts.
So.. To sum things up, The 2 stroke is the Chevy, The 4 stroke is the Caddie. Some love Chevys, Some love Caddies... Enjoy the ride.....
visit www.thatsdax.com
Old 06-16-2008, 11:28 PM
deacon's Avatar
And if I were a gm dealer I would rather sell the caddie
Old 07-06-2008, 09:01 AM
Fosscati Fosscati is offline
And the 4-stroke Staton NuVinci is the Bentley and the HT is the Lemon!
Old 07-06-2008, 12:05 PM
Don't you mean the Yugo?
