Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 08-02-2009, 10:12 AM
impression impression is offline
Default Engine won't turn over when clutch engaged.
So, i got my sbp shift kit installed and everything installed ( with normal exhauststill waiting on sbp exhaust )
But when in let go of the handle to engage the clutch it's impossiblew to turn over, with or without the spark plug installed it's so hard to turn the piston over my moving the bike forwars/backwars or pedalling, i can't get it to turn over when riding
Does anyone have any ideas ?
Old 09-15-2009, 04:02 PM
noco noco is offline
Default Re: Engine won't turn over when clutch engaged.
im having a similar problem...i can get mine to start still but it takes dropping the clutch a few times...so far ive pulled the clutch apart and i found that the friction materials are peeling apart...does anyone know of a better clutch than the oem one...that clutch has only gone about 5000 miles...during this winter i want to get a new carb,exhaust and a 36 tooth gear...i like to go fast...i just dont feel that the clutch will handle my plans...
Old 09-15-2009, 04:26 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
If I remember right other people have said there is a different starting procedure for SBP shift kits. You have to dump the clutch when you're leg is at the top of a power stroke and basically kick start the motor over.
Old 09-15-2009, 11:17 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I haven't used a shift kit on any of my bikes so I won't be much help with your problems with them you might want to contact the seller of your kit for help.
Norman
norms-iron-works.tripod.com
