Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Motorized Bicycle Trouble Shooting
Motorized Bicycle Trouble Shooting Use this area to post problems that may arise, if you could use some help in figuring out what is wrong with your engine and what needs to be done to achieve top performance.
Old 12-31-2012, 10:52 PM
crassius crassius is offline
Default Re: Idle Pulley Torques Inward
Another thing that can put excessive force on the tensioner is of the tensioner isn't aligned to feed the chain straight up onto the bottom of the rear sprocket, the chain can miss the teeth and wind around the outside of the sprocket (which makes it WAY too short).
Old 12-31-2012, 11:20 PM
maniac57's Avatar
maniac57 maniac57 is offline
The tensioner takes the most abuse when starting a new, tight engine. Do whatever it takes to secure it before you get hurt. Twisting to line up the idler wheel better and tack-welding the tensioner should cure your problems. If you decide to weld it, be sure it is positioned to give you the most range of adjustment in the chain BEFORE you weld it.
Old 01-01-2013, 06:58 PM
VTHokie VTHokie is offline
I ended up adding a tensioner that is bolted to both bars, and it feels extremely sturdy. I got the idea from the thread provided earlier
I gave it a test ride today and it held up superbly, but due to my inexperience in balancing the rear wheel, I blew apart my coaster brake and lost all the bearings. BUT, the tensioner held up perfectly, and I'm extremely happy with it.
Thanks for all the advice and suggestions.
Here are some pics:
Old 01-01-2013, 09:06 PM
GearNut's Avatar
GearNut GearNut is offline
Good job with that tensioner!
I am sorry to hear that your hub blew apart.
May you have better luck with the new one!
The_Aleman:
"It's a chinagirl. It's a sometimes fun little engine that often will break your heart. It's disposable.
Does not come with a fortune cookie."
________________________
ROTFLMAO!!!!!!
Old 01-01-2013, 10:50 PM
Thanks for the examples, GearNut. Those cushion clamps are priceless - I bought a variety in case I need them for future work.
Old 01-02-2013, 12:39 AM
thought it might be a rear sprocket problem causing all that force
new tensioner looks good & solid, but I'd guess the old one would work when your sprocket gets fixed
Old 01-02-2013, 08:03 AM
Ahhh that's an interesting point, and it makes complete sense. I'd be lying if I said I didn't notice a significant wheel wobble, but I selfishly wanted to get the bike up and running before I worried about it -- lesson learned. I'm sure you're absolutely right, and the wobble torqued the tension bar out of place every time. I should've gotten that dang wheel balanced to begin with. After watching a video on tightening / loosening the spokes, I realized that adding that rear sprocket probably threw everything out of alignment (because the bike itself was brand new and would be in no need of truing under normal conditions). Hopefully I can find a place to put it back together today
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
MotorBicycling.com
