Hi guys,
I'm trying to finish up my build and wanted to see what I could do about wide cranks.
I saw on gasbike.net that they have a one piece wide crank.
http://www.gasbike.net/wide-pedal-crank-kit1.htm
Anyone have any experience with a four stroke? I'm running a road master frame and a 98cc lifan motor which I'm pretty sure is similar in size to the 49cc hs motors.
If you don't think that would work, would this 3 piece wide crank work?
http://www.gasbike.net/Wide-Pedal-Crank-Kit-with-Conversion-Bracket.html
The description is very confusing since it says "with Conversion Bracket. Only works on bikes with small Crank hole. Conversion Bracket must be used with large crank hole." Does it come with the conversion bracket to convert my 1 piece to three piece?
Trying to order asap so any response is much appreciated!
Keith
Keith
