.. i already ordered a 44t rear sprocket and just need a bigger sprocket on the engine so i can add the chain.
hi !
what type/pitch rear 44t sprocket did ya buy ? as you know the Reduction box you linked at ebay is using like Chain size #20 or something which is miniature chain compered to bicycle chain sprockets, those wont work 2gether, wont mix and match 2gether.
edit iirc Pocketbike/minimoto Cagllari chain pitch is 8mm. and bicycle sprocket has 12,6mm pitch if you bought what im speculating that ya did....Unless if you bought 44t pocketbike rear sprocket ?
DAX sells 10t sprocket that fits into the mentioned Reduction box that you linked. it can use 415 moped chain and 1 of the bmx chains.
the Reduction box at ebay that ya linked is in 2 versions at least, with double row chain/double row sprockets and with single row chain/single sprockets. Reduction on the box can be 3:2 (9t & 29t sprockets inside the box)
bye
m
