the charging system on my '51 Chevy, which is 6v.. caps off around 8v on the old mech regulator... however that runs a generator and not an alternator, so it is pure DC voltage, but it still fluctuates from 6-8v at idle and a few of the bulbs on the car are the original bulbs, and are still burning... could use 8v bulbs ( yes they do exist ) but it would be dim at idle, and there hard to find..... another thought is a solid state voltage reducer.. they are easy to make from a few radioshack parts or, they are available as dash gauge voltage reducers for mopars from the 60's to the 80's... all gauges Mopar was using were 6v gauges. the reducers are not resistors but truley solid state peices. they take 12v and make it a constant 6v, but if it dropped below 12v, it will still provide 6v constant, and not fluctuate unless it's below 6v coming in... only issue is, they need D/C power which means running a diod pack
