Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips and Motorized Race Bicycles
High Performance Bicycle Engine Tips and Motorized Race Bicycles We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. Also check out some of our racing members builds
Old 03-19-2017, 12:19 PM
aarcher30 aarcher30 is offline
Default gt80 won't start
ran a gt80 with speed carb, reed valve, straight pipe. I ordered the keihin carb and now it won't run, I read up on the air fuel mix the idle and the clip setting. any other ideas like what jet and size to start with? I'm in Pennsylvania, and yes the bike ran prior the the new carb, also bought open banana pipe (no baffles).
Old 03-20-2017, 10:47 AM
Default Re: gt80 won't start
any ideas?
Old 03-20-2017, 12:09 PM
broke down the carb cleaned out the Jets which the main did have some melted plastic in it. but now I'm dumping gas out of the Jets with or without the bike running
Old 03-20-2017, 01:31 PM
Chaz's Avatar
Chaz Chaz is offline
Assuming that you've cleaned out anything that could hold open the fuel inlet valve, I would guess that the float is set too high. This would cause flooding and hard to start issues.
Just a guess from a chimp.
Just a chimp with a gun and an idea we should be free to ride our machines without gettin hassled by the Man.
Old 03-20-2017, 03:17 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
Check the needle valve, make sure it's not stuck or clogged and causing the floats to stick.
Old 03-20-2017, 11:26 PM
mike carter 2 mike carter 2 is offline
i have the keihin carb on my reed valve gt80.have no problems at all.well over 1000 miles on it.most of the time something iv worked on wont run i go back and recheck my work.a lot of times it me thats the problem
Old 03-24-2017, 10:12 AM
thank you all for your help, I bent the clip a little to adjust the float, runs fine now, thank you very much.
what's the best exaust gasket I can use for this gt80?
Old 03-25-2017, 02:05 PM
Chaz's Avatar
Good to hear you got it sorted. For an exhaust gasket I would look for one that has a rectangle-ish opening to match the cylinder outlet port. Get a few of them as they are cheap and spares will be needed at some point. I think Sick bike parts has one that is solid metal that could be hogged out and still have some meat on it. Not sure but worth checking out.
MotorBicycling.com
