Newly completed. GT2A aluminum frame. 66cc 2 stroke china engine with cut piston & drilled wrist pin, wrist pin and connecting rod bearings. Tuned carbonator and pipe, NGK spark plug and cap. Worksman 26"x 2.125" HD double wall alloy 36h rims, 11g stainless steel spokes, front drum brake hub with pressed bearings, 26"x 2.5" Maxxis Hook Worm street tires with presta valve tubes. Billet aluminum rear sprocket adaptor with 44t aluminum sprocket, 415 drive chain. 1 1/8" threadless adjustable coil spring fork, adjustable alloy stem, alloy handlebars, coil spring seat post and seat. Single side kick center stand. Engine is freshly broke in and runs great. 35 mph top speed. This is a new clean modern custom built bike. $1600 702-203-3361
