Anybody know Con-Rod size for Lifan a 2.8 98cc ??
racie35
1,702
usa
Resizing is easy and the crank probably survived. I don't think its $12 easy though so maybe a rod is easier.
miked826
1,748
7
Los Angeles
Visually the rod looks fine but when I start the motor it doesnt sound fine. I just went back into the motor and looked around and tightened the rod bolts again. Gonna restart now.
Do I need to remove the head to replace the con-rod? Is there any easy way to replace it?
racie35
1,702
usa
Should come out the top with the head off....not sure what it uses for a pin and clips.
miked826
1,748
7
Los Angeles
Which means I have to remove the engine from the bike to remove the head.
The 49cc Huasheng will take its place since they both do basically the same thing, performance wise. Might take it's place permanently. 150 hours on it and I have never seen the inside of the crankcase. I've seen enough to last me a lifetime with the 98cc. LOL
miked826
1,748
7
Los Angeles
Same result. When I rotate the crankshaft by hand, the #1 bolt (which is the one that's stripped out) clears the crankcase with ease. When I start the engine, it smacks the crankcase with every revolution. It's now leaving a mark on the inside of the case. The con-rod simply has too much play in it now. It's toast.
