I recently bought a rear LED light for my bike in the hope of attaching it to my white wire battery system, which is all 6 volt. I set up a zener regulator (schematic attached) so that I could have a 3 volt output for the light, which was originally designed to run on 2 AAA batteries. The regulator regulates, and the light lights, but when the engine running the light doesn't light, unless I hold down the push button (momentary) switch on the light, which means I can't go cycling through the different light settings and just leave it alone. When I do hold down that push button switch, the light flickers alot, and the flicker speed doesn't seem to correspond to the engine speed. I am hoping that if I put in a capacitor I can reduce engine interference, which is what I think is causing the problem. Trouble is, I don't know what size capacitor to use, where to put it, or which way to orient it.
Any ideas on a capacitor to use or an alternative solution?
Also, I can't post links (I'm a newbie) but if you go to ebay and search "Tail Rear Bike Bicycle Light Lamp 5 LED 6 Mode" then the first result is the light I bought.
