66cc Sky Hawk with a shift kit on a townie help
goldmatch45
10
Memphis, TN
I'm hoping to install a 66cc sky hawk & SBP shift kit on this aluminum frame towine. Do you think I can have a tube welded between the post the front derailer is hanging on and the top tube? Do you know of some other way of hanging the power train?
corgi1
2,272
KCMO
a longer reach front motor mount,even a longer rear one is possible,maybe one of the mounts they sell for the chopper bikes w/the angle tubes on a plate ,then mount the plate
corgi1
2,272
KCMO
and if there is room for the motor w/ the post welded in above the de-railer,that would work,,there would be a lot of room for the shift kit between the two, seat post and welded post
goldmatch45
10
Memphis, TN
the shift kit is mounted to the same tube as the motor so I think this is the easiest fix. If it can be done. I know nothing about welding aluminum. I do have a bike builder that I can talk to about this.
