AC to DC
jirble2
42
Exactly as the title says, I want to turn the white wire AC into DC. Apparently it can be done using 4 diodes, but I'm not sure on how to connect the diodes and which diodes to use.
So my questions are: Which diodes do I use?
How do I connect them?
A schematic would also be a great help if anyone has one/can easily make one.
jirble2
42
Thanks for the link.
Just one thing to confirm though: Once I have set up a rectifier, to charge a battery, do I simply hook up positive to positive, negative to negative to the battery to charge it, or is there some additional circuitry required? I'm planning on using a sealed lead acid battery if that's important.
BarelyAWake
7,194
21
Maine
Once you've the rectifier - I think that's it, you'll not hafta worry about overcharging or anything given how little these mags put out...
...but I will say I'm no electrical guru & it'd be best to contact one of the folks discussing such things - I simply cheated and used a genhub instead of messin' about w/diodes, rectifiers & other mysterious doodads that go zot in the night ;)
jirble2
42
A success story now: After reading through the thread that BarelyAWake provided, I've now managed to set up an incandescent lighting system with a battery. I will soon turn this to a LED system so as to minimalize power consumption.
dance1
BarelyAWake
7,194
21
Maine
:oops:
*cough* a minor correction lol, as the ways of electrics cornfuddle & terrify me - I provided only the link, our far more knowledgeable members provided the know how ;)
Glad to hear it worked out for ya tho (^)
