I don't get into political debates...
If you use the meter you (almost) mentioned, I would suggest against it because the use only 16awg wire which skews the results because of resistance issues with that gauge wire.
If price is not an issue, then I would deinitely go with the Cycle Analyst, because they use a shunt wired at the battery side which uses extremely low resistance to measure everything.
I use those (yes I have two of them, because I have two motors).
The Turnigy comes in at a better price (about half of the WU) and uses 14awg wire.
Yesterday I tried a test...
I rode one direction on a 16awg wire till battery depletion, (after recharge) I went a second dir on a 14awg wire and after a last recharge removed the Meter i was using and went on a 12awg wire....
(all flat, no wind)
Results (on a 36v 15ah LiFePO4 batt)
16awg (10' of wire and meter attached) = 15miles
14awg (10' of wire and meter attached) = 19miles
12awg (No Meter, 2' of wire from Battery to ESC) = 26miles!!!!
And that's only using one motor..
I use two motors normally, 36v 15ah (front) and 36v 25ah (rear), in conjunction and using the cycle analysts..
Top distance achieved?
With no wind and a flat surface, I was once able to max out.....
(drum roll, please)
An Amazing, 117miles averaging 20mph..
When I first started with the motors I was using WU meters and was only able to get MAX 80 miles distance..
So obviously for distance ability, the best choice is the Cycle Analysts, excpet for the fact that just those two meters cost me over $300.
16
