Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Intake & Exhaust
Intake & Exhaust The ins and outs - carburetors, manifolds, mufflers, expansion chambers and more to keep your engine running the way you like
Old 04-14-2017, 03:00 AM
Cylon's Avatar
Cylon Cylon is offline
Default Low Jet reference.
Posting low #60's jets for future reference.
Old 04-15-2017, 11:25 PM
Cylon's Avatar
Default Re: Low Jet reference.
Found out even 60 was to small for one of the bikes. I can't find any jets sized lower then 60, so I took one of my useless size 80 jets and filled it with solder. Now I just have to wait around for the micro drills to show up. Hope this works!
Old 04-16-2017, 01:07 AM
Cylon's Avatar
I believe I found a good set of micro drills;
http://www.ebay.com/itm/21pc-Mini-HS...-/201216863451
Old 04-16-2017, 02:17 AM
TheNecromancer13 TheNecromancer13 is offline
You can get a micro drill set at harbor freight. They aren't the best quality, but for drilling through solder they work just fine.
125cc lifan build 79cc predator series
There's no replacement for displacement. Bigger is better, and too much is never enough.
Old 04-16-2017, 11:50 PM
Cylon's Avatar
So the head seemed to not seat properly with the new high comp head. I put the old head back it it proceeded to run rich so I looked at the carb is it was leaking extremely bad seems like the gasket was fubar. Now I need to order a new carb and see where I can go from there, time to rejet all over again. X3.
Old 04-20-2017, 11:19 PM
Cylon's Avatar
I picked up the micro drill set from harbor freight and tried to drill into the previous shown jet in pictures above. Didn't work out so well as it was my first time and I used to much solder and kept breaking the .45mm bit.
Thankfully it came with 2 of each bit but no .50 or .55 so I will still have to order that eBay kit. Can't wait to test it out and see how it works after I fix the carb, from changing the jet so much the bowl gasket leaks like a sieve. Will order a whole new carb as well.
Here's the Harbor Freight micro drill set and what my newest jet looks like with a .45mm hole drilled into it.
MotorBicycling.com
