Hoping to not look like I am singling you out here...
The ideology you have is close but your interpretation is very misleading, so misleading I don't know where to begin...
Exhaust gases actually occupy less space (as they cool, as it is the HEAT that produces power, expanding on the piston) than unburnt inlet gases, this is why the exhaust valves are smaller than inlet valves in a 4 stroke.
It is actually a slower burn that will make more power, the higher the compression, the more advanced the spark the more we have to slow and cool the burn to prevent detonation.
14.7:1 is the ratio where 90 to 100 octane pump fuel burns the cleanest, the hottest burn will be much leaner than this.
FWIW I still think that the only good thing these black boxes have to offer is separating the CDI from the coil, just like about every other cycle manufacture out there...
A high end ignition system where tailored advance curves, like what they use in the kart racing fraternity would show improvements where needed.
I'm sorry I don't know enough about the internal magic of a two stroke as yet but I am learning, as far as I have seen there is very little difference in the actual needs of the 2 stroke compared to the 4 stroke, event timing, ignition timing, mixture and spark...
Having a good background in V8 4 strokes I can tell you that there is alot of mis information in these paragraphs alone, let alone your general understanding of how the internal combustion engine makes power, not trying to have a go at you but if you are going to offer credible information for people to tear strips off one competitor or another it may as well be correct information.Basically an engine (2 or 4 stroke) is powered by the expansion of gases, the conversion of gasoline and air into CO2 and other exhaust gases. Exhaust gases want to occupy considerably more room than oxygen and gasoline droplets (this is how Dynamite works too, it's not the flame that's deadly, it's the conversion of the materials into CO2 so rapidly that it produces a shockwave). This forces the piston downward. The faster you can make that flame burn through the chamber, the more power you will achieve. This can be done with more turbulence (better mixing), higher pressures (compression), ignition point (shortest distance, depends on if you run 1 or 2 plugs. 1 plug in the center for shortest distance to all sides), Air/fuel ratio (14.7:1 by weight burns the fastest, too much or too little will leave unburned oxygen or fuel), ...
