I have a grade on my commute that is pretty steep. As I'm approaching, I give the bike some gas in order to build up engine rpms.
I've found that if I give it full throttle, then I'll lose rpms and the engine is clearly on the way to stalling. But if I give it about 2/3 throttle, then it'll maintain that particular rpm, or close to it anyway, and the bike will climb the hill.
Does this sound to you as though I'd benefit by swapping my jet for a bigger one?
I've never actually swapped out a jet. But I have some spares on hand and I'd think I can figure it out. I suppose a socket on the end of an extension straight down the carb throat is the way?
And is the jet likely to be my trouble? Or do other things come to mind?
