Sprocket!
alienboy366
114
OC, California
Having a hard time contacting jim over at manic mechanic for a sprocket. Who sells a good and cheap sprocket (36t)? Worth buying the adapter? If not, where's the cheapest place to purchase a sprocket using the sandwich type attachment method?
rustycase
Gutter Rider
May 26, 2011
2,746
5
Left coast
Worth it??? YES!
Not sure of the best source, but a sprocket adapter is a major improvement over a rag joint!
I think it should be the first improvement made to an ht kit.
Best
rc
GothTech
77
ga
i just happen to have a 36 tooth spocket off a old build its a pirate cycles spocket
SdCruizer
108
San Deigo
I just installed the one pirate cycles sells
4 teeth more then stock, so far helps on all the hills and acceleration from a dead stop is better
I also think it makes the bike quieter, either the way its designed or the way it mounts
Im almost silent when rolling now
I like the fact you have a small amount you can press it in or out and easily swap sprockets
Plus looks alot cleaner too
it is pricey though
