I am new at this. . . obviously . . . and am having the worst time ever. I just want to get on this thing and ride.
Here's the back story:
I bought a Grubbee Skyhawk 80cc engine (the one on here, or king motor bikes that has the most reviews) last spring and assembled it through the course of the summer. I had everything working, except the chain was never tensioned right and i periodically had throttle cable trouble. . . Let's just say it 'kinda' worked, but never really 100% . . or even 90%. Anyways, I made one 5 mile round trip and then for the 124th time, the chain busted. It was late fall so I decided to wait until now to solve the chain problem.
I did that, had to get new CDI, and put a break on the cruiser it is mounted on. Through the testing process, i realized i wasn't sparking, so Using an Ohms meter and such, It came down to a new spark plug and CDI.
However, this is where I need help.
The engine did not start right away like it did in the summer. And it didn't start until I had the choke cable fully pulled on the choke lever. At this point, the engine kicked on, but continued to accelerate at a constant rate. The throttle was completely unresponsive so naturally I went for the kill switch. Before i could even due that, the choke lever arm vibrated a few clicks down and then the engine disengaged and shut off. Through a series of 'start and stops' i allowed the engine to warm up. Now the engine engaged on less choke, but it still continued to accelerate AND once i pulled the choke lever down past the pitch at which the engine started, the engine would turn off. Meanwile throttle is completely unresponsive.
I know it will require some carb work, but what???
Other things include: Same gas/oil as summer, throttle cable has some slack but successfully pulled barrel when twist throttle was tested, gas flow is 100% because it smells and some places visible, it is 35-40 degrees F here when i tested it. it has the carb with the red air filter cover.
