Problems with "80cc" Clutch
GearNut
5,104
11
San Diego, Kaliforgnia
That cog is keyed to the shaft by a woodruff key, a small half moon shaped piece of metal that fits into a groove in the cog and a notch in the shaft. The woodruff key prevents the cog from slipping on the shaft. Yours is definitely slipping. Remove the cog and inspect the woodruff key. It may be missing from the assembly.
The gear is attached to the shaft by the large slotted screw you can see in the center of it. Behind the screw head is a toothed lock washer that is supposed to prevent the screw from coming loose. If the woodruff key is missing, the lock washer will have difficulty doing it's job as the cog will be spinning on the shaft.
The threads in the cog are there for the puller tool to thread into to facilitate cog removal.
GearNut
5,104
11
In posts 1 through 3 of Norm's clutch tutorial he demonstrates the removal of that cog and shows the parts involved in it's assembly.
http://motorbicycling.com/f4/bicycle-engine-clutch-222.html
The whole tutorial is about the clutch, but since that does not seem to be the problem, you do not have to follow the whole tutorial.
By the way, your gears look awfully dry and rusty. They should be well greased with a quality automotive high temperature grease.
Halifaxcycles
15
Halifax Nova Scotia
Found the problem! I was about to use my new hand impact tool that was ridiculously over priced for the one time I'll ever use it when I discovered the small cog is cracked. I still haven't "taken a whack at it" yet and I'm nervous to do so as I know little about it.
The small cog is cracked. Advice? Any recommendation for somewhere better then Zoombicycles to go for part, I'm in Canada so I suspect it's my best option.
The Other part of the matter is the tool cost half the price of a replacement engine..
KCvale
3,966
57
48
Phoenix,AZ
Found the problem!
Well, having another engine kit around to scavenge from is not a bad thing if you plan to build more than 1.
I know what you mean about tool costs though, even shopping at Freight Harbor with coupons it gets costly. I have probably spent more than I have netted on bike sales on tools so far.
GearNut
5,104
11
I recommend getting the gear from Zoombicycles. You will have a better chance of it fitting correctly as it most likely will have come from the same factory that made your engine.
chainmaker
2,634
69
48
Ma USA
Im betting the same guy made our motors, same thing here cracked cog, just a hairline but it still works, I am waiting for a replacement. I bet the key is missing from yours as well. My guess is either the shaft was not finished enough and a bit too big, or the shaft hole was a little too small and whoever was assembling them had to tap it a bit too hard forcing the parts together resulting in the crack, and the key out . I bet there are a bunch of other engines waiting for this to happen to, due to incorrect or too great tolerances in the machining of parts. Thats why they are so affordable.
dnut
Cheers
Hg3223
6
Indented head
Hello any one can help me
I have fixed a few small problems already
New ngk spark plug
New spark plug cover
Fits like a glove and worked really well for a few days
N O W
When I engage the clutch rear wheel locks completely can't roll it backwards or forwards at all
I can lift the bike and turn the wheel by yanking!!! it
But noticed the small clutch doesn't turn??
crassius
4,032
158
USA
first, take out the spark plug - if it doesn't turn now it is probably a chain problem
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Spark plug out small clutch not turning and the back wheel locks chain fine bike not :.(
I'm not understanding what you're saying here.
What are you calling "the small clutch"?
With the clutch 'engaged' (handlebar lever unsqueezed) the rear wheel will be hard to turn because you are fighting engine compression as well as drag from the gears, etc.
If the clutch is 'disengaged' (handlebar lever squeezed and cable adjusted correctly) the rear wheel should spin free. If it doesn't either the cable is too loose or the chain is bunched up on the engine drive sprocket. This is usually do to a chain that is too loose and/or misaligned sprockets.
Hg3223
6
Indented head
I wish it were that easy guys
Chain moves freely I can ride it around with the clutch disabled but as so as I engage it LOCKS
The small thing that's connects to the clutch won't turn at all (( Oo
Thats a picture The big O" the clutch the small o " is the thing thats Stuck locked seises to move I'm no mechanic
wish I new what its called
Hg3223
6
Indented head
Got it going :) Did a bit of reading on pistons and how they work
Fixed it by only taking off three screws and turning a spanner twice haha ha
"Two weeks later"
Frustrating fun toys
