Copied from manufacturers site:
Notes:
1. As for the 80cc, in fact there is no such cc bicycle engine in china market, we called our 47*38(bore*stroke) engine F80 before ,but now we correct it, because its displacement is only 66cc(from EPA test report).
2. How to caculate the engine capacity. The fomula is listed below.
The volume of a cylinder=(bore area)x stroke
Bore area= Bore x Bore x pi / 4. (pi has a value of 3.14159)
Take our ZM70-P for example, its bore is 4.7cm(47mm), its stroke 3.8cm(38mm)
4.7×4.7÷4×3.14×3.8=66cc
I hope this is helpful to some of you. I was sent the entirely wrong engine from an online supplier of kits. I went ahead and installed the kit and it works fine, but while trying to inspect the internals I broke a ring and without any documentation that came with it, I was out of luck trying to ID the displacement. I ordered a set thinking it was the 49cc model, but instead found out that it is the 66cc version.
Is there any markings on the blocks of these engines that says what make they are?
Notes:
