The topix here is the potential performance gain and ease pf measurment by using a flat top or dished piston rather than a domed one .
It is my experiance that when a domed piston is used in a high comp motor it has a tendancy to direct the combustion down around the dome and into the rings thus adding to blowby, where as a flat top or dished piston would contain the brunt of the charge right on top of the piston and create more downward force,and more compression and less blowby via containing the charge ontop instead of guiding down to the rings .
Though one could argue that directing the charge at the rings with a dome shape would only help the rings expand more and the blowby would be negligable. Also the dome shape could be said to help aid with squish band funtion by creating a tighter squeltch where the dome and squish angle meet where as a flat top piston leaves a wide squeltch angle or needs to be run with a horizontal squish .
One reason why i want to try running a flat top piston is so i can set the flat top piston to a perfect zero deck hight with the jug
