I am having trouble deciding if i should go with a 90mm sturmey drum brake on my front end or if i should do a avid bb7. I currently have a 70mm drum in front and back and i feel like i need a little more power. Ive had a few too many close calls.
slime your tubes. That stuff works!I need to replace the tube on my rear tire. The problem is taking off the rear tire, how do I do that?
Ditto. Avid BB-7 on your front wheel and you won't have to worry about stopping power ever again.go disc and you will never go back. I run an Avid BB7 on the front and I like it a lot.
i got a set of disk breaks(front and rear) for $50.. and even they are alot better then my tectro v brakes that came on my bike.
my v breaks never failed me.. and if your bike is not set up for disk, then its will coast a good deal to put them on for sure. my bike brand new came with v breaks but was also set up for disk.(hubs and mounts)That's all fine and dandy. But one must have disc brake hubs to use disc brakes.
I've put over 100k miles on pedal bikes and find v-brakes to be adequate. Discs are a dream for me lol
im building a new set of wheels on some 36hole halo freedom disc rims so no chance of rim brakes for me. Im still super tempted to do a drum. The look of the deep v rim and high flang hub will look soo cool.That's all fine and dandy. But one must have disc brake hubs to use disc brakes.
