I really don't like dual brake leavers but if I was to use one I'd like this. Duplex lever lets disabled cyclists activate both brakes with one hand
Here's the type that I use on my builds. Sometime you can find them for less on eBay:I was just about to make a post about dual brake levers. I'm thinking about getting onr. Can someone recommend one... cheaper than that $63 one though.
How does that work, it looks like when you pull the lever, it pushes the brake housings forward, rather than pulling the inner cable inward, as with conventional levers.i just got a set of those paul component levers. They solved my braking problems. You can't beat the quality of paul components.
Works well, I have been using the same one since 2009. I mounted it on a disabled coaster Cruiser.How does that work, it looks like when you pull the lever, it pushes the brake housings forward, rather than pulling the inner cable inward, as with conventional levers.
