reed valve questions
wheelbender6
4,059
221
TX
You can fab a housing for it from flat steel or aluminum stock. Search the site for "reed valve".
Allen_Wrench
Resident Mad Scientist
Feb 6, 2010
2,784
26
36
Indianapolis
I'm thinking of doing this myself. Let's keep this thread going and tell how we do what we do. Could be a learning experience.
Allen_Wrench
Feb 6, 2010
2,784
26
36
Indianapolis
i just got it and its a shade too small. i would get a bigger on if i was going to buy another one
Hmmm...Sounds like we need to find out how big the chainsaw is that this reed valve belongs to, then research a bigger chainsaw. I only hope this reed valve isn't the biggest they have.
corgi1
2,272
3
KCMO
I typed reed valve in their search ,,there are a lot of different designs,I think we need to figure out how to tell the CC's of a saw
corgi1
2,272
3
KCMO
I looked for 66 cc chainsaw and finaly found 60 if i remember ,it may have been the carb and reed valve at the end of the list that led me to it,I think the saw was huscavara(spelling) Rancher
460 or something and the thing wasn't that big in the pics,and a 20-24 inch bar is all,I've had larger ones
Slowrollers
65
downers grove Il
Piston port motors are alot different than reed valve motors....I dont think fitting reeds on would help....please correct me if im wrong.....
Case induction is a possibility.......
Allen_Wrench
Feb 6, 2010
2,784
26
36
Indianapolis
Well, I know the piston port design was meant to use the natural direction of airflow and backpressure to keep the airfuel mix in the area of the cylinder just long enough for the piston to squeeze it and the spark to blast it. What I'm hoping a reed will do (which may be very little) is keep more of the airfuel mix in the cylinder, rather than some of it always blowing back up the intake manifold. On my old bike, it was never very serious, but it was always there. That's wasted power.
And if the reed doesn't work, we can take it off and say we tried.
FreeWheeler
240
Maryland
I'm about to try this, ordered the reed. I've been reading both the other threads and someone listed a port modification from Hodaka to control the case pressure. That tells me a reed could do something when added to an engine built without. :)
I'm guessing any reed from a saw shoule do, but I seriously dont know and will find out.
Allen_Wrench
Feb 6, 2010
2,784
26
36
Indianapolis
I'm still on the mend, so I haven't been able to do much tinkering on my end. But if you manage to get positive results yourself, please post. And let us all know how you did what you did, when you can. There are a few of us who want to try this. What you learn could pave the way. :)
camlifter
1,033
16
36
acme labs marion ohio
we tried using reed valves on the HT. didn't work out very well. the piston port is way different from a reed port or case port engine. you also need a good sized hole cut into the right spot on the piston skirt to use reeds on a jug inlet engine. heres what we came up with. but we gave up on it after finding a much better running engine by just raising the ports and using an expansion chamber exhaust.
FreeWheeler
240
Maryland
Imagine a Chna Wench on steroids: Kawasaki 750 H2
The 750 H2 stock is a piston ported 2 stroke and this guy fit reeds to it. His cyclinder modification looks alot like that Hodaka modification. Interstingly, somewhere in that link he talks about the loud rattles and slap that these engines had. Sounds familiar.
FreeWheeler
240
Maryland
OK, so did you lower the intake port and cut holes in the piston?
I read in another thread that someone had trimmed their piston skirt AND lowered their port without adding reeds and lost all power. It was suggested that adding reeds to those failed mods would have restored power plus some.
