The Schwinn Riverside with 79cc predator
BelayBoy
159
illinois
http://motorbicycling.com/showpost.php?p=535817&postcount=156
As I mentioned on the first page I purchased plate with mounts from http://www.bicycle-engines.com, then I purchased only the plate from agk.
Now to my original question
Does anyone know where I can purchase brackets for http://www.bicycle-engines.com plate mounts? (they do not have any extra brackets for sale)
I lost front bracket during 35 miles ride, can anyone help me out here. I really would like to go back on the road.
Please
BelayBoy
159
illinois
this bike is so much fun to ride its unbelievable, just have to be more careful with bolt on items. i will figure out the mount eventually.
79hf engine is very powerful i ran 4 different gear ratios with no problem
11t, 22, 10, 44
11t, 22, 13, 44
11t, 22, 15, 44
11t, 22, 18, 44
the only issue i had was with my homemade jackshaft mount it had bit of flax whenever i would accelerate, thats why i will go with sbp js mount
greaser_monkey_87
397
USA
I'm not sure where to buy those exact clamps, but a pipe clamp might and I stress, MIGHT work. If you know your downtube diameter or can measure it with calipers, then go to home depot or lowes and get a pipe clamp that size or as close as possible. It may work and it may not, but they only cost a couple bucks and might get you back on the road. They are likely not to be as strong as the clamp you lost, so I'm going to suggest two things. One, you definitely want to cut a shim long enough to hose clamp to the downtube. Two, if you don't already have the motor braced to the frame (aka third motor mount), I strongly suggest looking into that.
BelayBoy
159
illinois
It is almost impossible to align the SPb Jackshaft mount with rear wheel sprocket. It is really good mount but I do not recommend it for the predator. I am going back to my original mount.
