Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 2 Stroke Bicycle Engines & Kits
2 Stroke Bicycle Engines & Kits 2 stroke engine kits need careful installation and setup, find out how from our professionals here!
Old 01-05-2017, 02:35 PM
Venice Motor Bikes's Avatar
Default Re: Overpowering the Clutch no matter what.
Tighten the flower nut down as much as possible to where the clutch still works normally.
I've always had this problem with my race engines.
Some clutch shaft main springs aren't as strong as others, & you've already done all the sanding & cleaning the pads; so if there's still slipping?, try swapping out the main spring.
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 01-05-2017, 06:40 PM
StevenMain StevenMain is offline
Just swapped main spring yesterday but until my new build goes together who knows if it will grip. If not I'm making semi metallic pucks.
MotorBicycling.com
