Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 09-01-2016, 02:33 PM
pulsar2121's Avatar
pulsar2121 pulsar2121 is offline
Exclamation Need Help Finding a Sprocket That Fits a 20" Wheel
This post is not about gearing issues, but rather fitment issues. I'm currently working on a BMX build and I'm having trouble finding a sprocket that fits the spoke pattern of the 20" wheels.
I'm trying to get the standard 9-hole sandwhich mount sprocket to fit and it seems like no matter how I rotate the rubber ring, one of the holes aligns with a spoke intersection.
Does anyone know what kind of adapter and sprocket set up would fit this wheel? FYI, the hub is fairly large since it has a coaster brake.
Old 09-01-2016, 04:10 PM
Kioshk's Avatar
Kioshk Kioshk is offline
Default Re: Need Help Finding a Sprocket That Fits a 20" Wheel
In my own experience, I've gotten away with less bolts than that. 6 with a rag-joint, 4 when I jerry-rigged a sprocket; routed to fit over a disc-brake interface. You should be just fine with 8 bolts.
Old 09-01-2016, 10:32 PM
mogollonmonster's Avatar
mogollonmonster mogollonmonster is offline
Geeze, here I go again... Grab your (or your buddies) trusty, not rusty, calipers and measure the hub body, in between the spoke flanges. 1.5 is a really common coaster brake hub diameter. Manic Mechanic sells that size and reducer bushings. Pirate Cycles sells a number of sizes, but I cannot speak of their quality. The MM unit is very well made, and fits my hub like a glove.
This style sprocket adapter allows for you to properly align the drive sprockets, which is pretty critical for a number of reasons.
Kiosk is right though, one missing bolt out of nine won't hurt much, at least not any more than the crappy ragjoint itself. The rag joint is one of the weakest links in the ChinaGirl kit, losing points only to the Scrapaloy hardware.
Old 09-11-2016, 10:45 PM
pulsar2121's Avatar
I like the idea of the hub mounted sprocket much better than having an out-of-round spoke mounted sprocket. I bought a digital caliper at Harbor Freight and measured up the hub on the rear wheel.
It's 1.70 inches in diameter. I did some searching on bikeberry.com and ebay and all I'm able to find are adapters for hubs that are 1.5 inches or smaller. Do you know here I could find an adapter that fits my hub?
Old 09-13-2016, 05:32 PM
Gasbike and bikeberry are NOT your friends. Check with pirate cycles, if not them try www.mmbikeparts.com I'm pretty sure George has them in that size. Higher quality parts and workmanship.
Old 09-13-2016, 10:05 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Originally Posted by pulsar2121 View Post
This post is not about gearing issues, but rather fitment issues. I'm currently working on a BMX build and I'm having trouble finding a sprocket that fits the spoke pattern of the 20" wheels..
How many spokes on your wheel?
9 bolt rag joints are made for 36 spoke wheels.
Old 09-14-2016, 08:47 AM
curtisfox curtisfox is offline
Yes, and hub adapter won't fit through wheels with more spokes, either i don't think.......Curt
Old 09-14-2016, 01:00 PM
hub adapters fit on 48 spoke wheels because 3 divided into 48 = 16.
But I don't know of any made for 1.7" diameter.
Old 09-14-2016, 01:09 PM
Good to know! Have not used any yet. I sorta make eveerything i need...........Curt
Old 09-20-2016, 02:35 PM
Wild Bill's Avatar
Wild Bill Wild Bill is offline
The problem with using a rag joint or hub adapter on a 20" wheel is that you cant gear it as high as you need to get a decent top end speed if you are running a china girl engine. I laced up a disc brake hub and there are smaller sprockets available to bolt to the disc hub. I make up my own and I have run as small as a 20t but as long as you have an engine that turns higher rpms than stock anywhere from a 25t to 28t work pretty good. My Sons race bike hits 46-47mph on a 28t. There are disc mount sprockets on ebay that go down to around 26t. A 30t or bigger on a stock engine will be pretty slow.
My race bike runs 20" wheels and uses a hub adapter with a 34t sprocket but that engine is a KTM and turns a lot more rpm than a china girl so I can use the adapter with bigger sprocket like 34T and still hit around 47 mph which is what I need tor the track we normally race on.
Its all fun and games until someone loses an eye, then its just fun!
MotorBicycling.com
