Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 10-04-2016, 09:23 PM
mat_man mat_man is offline
Default Re: Rear Sprocket adapter.
With a good solid axle. These Steel Disc Brake Hubs might be bullet proof.
($23 set, free shipping)
1 Pair Mountain Bicycle MTB Disc Brake Hub Set 36 Hole Durable Steel 3Colors
http://www.ebay.com/itm/1-Pair-Mount...eeH0Zl3tb8XxRA
Old 10-05-2016, 10:54 AM
Kioshk's Avatar
Kioshk Kioshk is offline
Originally Posted by TheNecromancer13 View Post
You can space out the disc brake adapters as well if you get a little creative. I made some spacers for a friend of mine by cutting doughnut-shaped discs out of aluminum and drilling holes in them for the bolts, just make one with the desired thickness of aluminum to get the spacing you want.
I was fortunate to have had no alignment issues, but standard steel washers could be used to raise the adapter off the hub to the desired clearance quite reliably.
Can't praise the BicycleDesigner adapter enough...really high-quality stuff. It's held up excellently, and there's been no discernible wear on the custom fat aluminum-alloy sprocket that came with it.
Old 10-05-2016, 11:27 AM
TheNecromancer13 TheNecromancer13 is offline
Yea, that was what I did before I made the aluminum spacer. I just thought that all the washers looked kinda trashy.
MotorBicycling.com
