Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Lighting and Electrical
Lighting and Electrical Things that go ZOT! Ignition components, batteries, lighting and accessories
Old 06-11-2016, 11:29 PM
Schrockie Schrockie is offline
Default Re: Anybody know anything about the magneto magnet
Now that everyone has help to get my bike running, I still have a question about timing. It's a one cylinder engine with a woodruff key on the magneto. You don't have a second cylinder to test against. I'm not knocking anybody, I just know with a 4 cylinder I can turn the distributor until it fires right. One cylinder timing? I looked at Cassius's thread on this and couldn't understand what or how he was doing this.
About changing out the carbs: why didn't the first one work,I think I bought the next higher upgrade from bikeberry, then went to a stock and almost just fine. Needle position? If someone could provide a credible/useful link on this subject so I can figure why it wasn't working would be helpful.
On this rebuilt motor, take off is slow, lit bit sluggish until 10mph, head temp 290+/-f
I appreciate everyone's help, and thanks go out to you
Troy
Old 06-12-2016, 12:06 AM
maniac57's Avatar
maniac57 maniac57 is offline
Troy
The only easy way to change timing on a chinadoll is by modification of the CDI for adjustable timing.
Any mechanical change would involve custom machining or offset keys or some such. Not enough gains to be worth the effort.
Do it with electronics.
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 06-12-2016, 08:44 AM
I am: minus a CDI and a gas tank for my 2nd bike. Can anyone point me in right direction?
Thanks,
Troy
Old 06-12-2016, 11:54 AM
crassius crassius is offline
my timing thread was to check timing for no-start problems - one would use a timing light to check it
standard carb is usually best for standard motors - any "performance" carb is always a lot of work
Sometimes I sets and thinks, sometimes I jes sets.
Old 06-30-2016, 01:17 AM
maniac57's Avatar
http://motorbicycling.com/archive/in...p/t-28439.html
MotorBicycling.com
