Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Stretch Cruiser & Chopper Motorized Bicycles
Stretch Cruiser & Chopper Motorized Bicycles This area is for sharing all about our custom stretch cruisers and choppers.
Old 01-16-2016, 02:37 AM
Micargirovergt Micargirovergt is offline
Default Re: micargi rover gt build
It's a bit difficult but well worth it you will need to change to a 36 spoke rim and you will need to get or make an extended motor mount I opted to purchase one
Old 01-24-2016, 04:01 PM
JoeMetro JoeMetro is offline
As stated earlier, you'll need to switch out at least the rear wheel. Even the manic mechanic sprocket adapters won't work with that many spokes.
I would highly advise avoiding the use of anything between your bike frame and motor mounts. The rubber won't do much, and it's much better to have a flush metal on metal contact. I'm not sure but to me It looks to me like you won't have much problem using a manic mechanic front motor mount and jimmying something for the rear mount.
As for mounting the gas tank, I don't think extra wide mounts will do it. My bike (fito modena GT) also has a really large top tube. I just cut up a belt and drilled holes to make it work, along with foam mounting tape underneath the tank. It has a little wiggle to it but it gets the job done.
Old 01-25-2016, 10:08 AM
biknut's Avatar
biknut biknut is offline
I built this one a few years ago, and it's a little different, but it might give you some ideas.
https://www.youtube.com/watch?v=dXysa1FNzEs
Old 09-17-2016, 12:08 AM
joshuabosseler90 joshuabosseler90 is offline
What length are your triple tree forks?
Old 09-17-2016, 02:53 AM
Tyler6357's Avatar
Tyler6357 Tyler6357 is offline
Never use jnm vibration motor mounts, just don't do it.
MotorBicycling.com
