Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 05-09-2012, 09:51 PM
Mightyboosh Mightyboosh is offline
Default Re: Motorized Bicycle Gear Calculator
Hard part is finding things when I don't now wat to look for.
Old 08-10-2012, 07:28 PM
motorhedfred's Avatar
motorhedfred motorhedfred is offline
I'm trying to figure pulley sizes for a 29" tall tire with all belt drive. Near as I can tell, the tire has a rollout of 91 1/2". That would mean about 692 revolutions per mile. On a bike with the cajones to pull 60 MPH at 7000 RPM, that would be 10-1 final drive ratio, but I doubt a 99cc HF has enough.
I have no intention of riding that fast, or revving that hard....it just seemed like numbers easy to work with in my head with my own wierd formula.
I'm not sure what to shoot for.
MHF
A stopped machine is like an un-eaten sandwich. It might look really good, but you canít get full enjoyment until you use it like it was meant to be used. So eat your sandwich, and ride your bike!
Old 08-10-2012, 07:43 PM
Yeah I don't know of a calculator for for a belt drive. Even then it wont be right. It tells the speed of the tire with 0 weight and 0 resistance. My predator gets to above 45 but the calculator said it do 90. Make sure u take out the complete governor mechanism. Other wise u wont get close to 7000rpm.
Old 08-10-2012, 07:54 PM
I should mention that I was calculating around a 3" drive roller FD.
MHF
Old 08-10-2012, 11:53 PM
ducatiluke ducatiluke is offline
my 148cc runs 6:1
my 31cc runs 22:1
so 10 to 1 for a 99cc sounds like a good starting point
10:1 at 7000 rpm with 29" should give you 17mph at 2000rpm
and 60mph at 7000 rpm
love to post pictures but this web site has size limits
i have a great program that gives you speeds after u enter all data ratios
wheel size rpm ect
Old 07-29-2014, 12:50 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Best gear ratio calculator!
The program can be downloaded from http://jimsitton.net/ratiocalc/
Just right click on the file gearratio.exe
and select "save link as" and put it somewhere you can find it again.
Once it's saved, double click on the gearratio.exe file and it will run.
The program allows for up to three ratios in series.
If you have fewer just leave the unused ratios set to 1:1.
The program will also calculate speed based on
engine RPM,
drive ratio,and
wheel diameter.
Be sure to measure the outside diameter of your wheel for accurate results.
MotorBicycling.com
