Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 11-27-2012, 11:25 PM
JonnyR JonnyR is offline
Default Re: Gear Ratio with Predator 212cc and jackshaft
why would you leave the governor its easy to take off or out
Are you callin' me crazy! just cuz i got a hotel in my foot doesn't make me a boogali moogali moogali
Schwinn jaguar with a 66cc flying horse
they all run fantastic till they don't
smoke tires not drugs
YES! YES! JESUS H. TAP-DANCING CHRIST... I HAVE SEEN THE LIGHT!
http://www.youtube.com/watch?v=YoPVC4YxDlI
http://www.youtube.com/watch?v=y0O7_...eature=related
Old 11-27-2012, 11:28 PM
potbunny potbunny is offline
well im on a budget and couldnt modify the frame...i guess i could take it oput but i still am so confused on gear ratios. whats the fastest speed and ration i could use if i removed the governor? would i be able to ditch the jackshaft? cust i would only use a bolt-on-the-engine kind and i cant find one for the 212cc
Old 11-27-2012, 11:36 PM
the AGK bolts on to all the predators
if you dont have a good budget i would think twice about a 212cc build or at least take your time with it because you are going to have to make/modify a lot of parts if you want to do this if you dont know what you are doing real well you will hurt yourself with this engine
Old 11-27-2012, 11:39 PM
ok illl think about it but i will be with my uncle who can help me with the frame and stuff. i will remove the governor, what ratio will i use not to get the best speed and take off from a dead start?
Old 11-27-2012, 11:43 PM
just get a AGK jack shaft and max torque clutch and build from there call them up they will help you out
http://www.affordablegokarts.com/mm5...gory_Code=99cc
Old 11-27-2012, 11:52 PM
oh ok thanks for all the help...one more question, how do i know the idle and max rpms without a goverbor?
Old 11-27-2012, 11:54 PM
idle is always around 2200 and max is 5500 rpm with stock internals you need a tachometer
Old 11-27-2012, 11:59 PM
oh ok thanks so much youve really cleared things up in my head
Old 08-25-2013, 03:29 AM
kksbunny kksbunny is offline
Hey, excuse me, so i recently removed my governor, and i was wondering if i just do about 5000 rpm without upgrading any other part like freewheel, piston rod...... Is it ok to do that? please respond!!!
Old 10-14-2016, 08:09 PM
Austritch Austritch is offline
Hey! Just checking in with my 150cc GY6 fat bike build. I am beginning the final stages with doing my gearing. So far I have (on paper) a 5:1 (12 on the clutch and 60 on the axle) gear ratio on a 26 inch drive wheel. I intend to mount the rear sprocket to where the rear disc brake rotor is now to avoid pressure on the spokes. I will still have and use the front disc brake. What do you think about this ratio? Will it eat up my centrifugal clutch? I think the max rev is about 7000. Questions? Comments? Concerns?
MotorBicycling.com
