Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 11-27-2012, 10:55 PM
potbunny potbunny is offline
Default Re: Gear Ratio with Predator 212cc and jackshaft
and how fast do i go? and what if i get a 1800 to 2000 clutch i found
Old 11-27-2012, 10:58 PM
JonnyR JonnyR is offline
your clutch wont work then the engine idles at 2200
top speed is determined by rim size and max RPM
Are you callin' me crazy! just cuz i got a hotel in my foot doesn't make me a boogali moogali moogali
Schwinn jaguar with a 66cc flying horse
they all run fantastic till they don't
smoke tires not drugs
YES! YES! JESUS H. TAP-DANCING CHRIST... I HAVE SEEN THE LIGHT!
http://www.youtube.com/watch?v=YoPVC4YxDlI
http://www.youtube.com/watch?v=y0O7_...eature=related
Old 11-27-2012, 11:00 PM
and what is my top speed? is that the fastest i can possibly make it go to start out from a dead stop? i found a clutch that engages at 1800 to 2000, would taht help?
Old 11-27-2012, 11:04 PM
no because it engauges below idle so you cant start the engine without it engauging top speed with the governor is not going to be to high 30ish without it 50 ish
Old 11-27-2012, 11:06 PM
so what is ur final desision i should use to get the highest speed...and what would that speed be.
Old 11-27-2012, 11:08 PM
if you set it up right you end up like this
http://youtu.be/JsKmNiie_J8
Old 11-27-2012, 11:13 PM
so i need a 12t clutch 22t in 11t out 44t rear and that will amke me go 50 mph? how do u calculate top speed?
Old 11-27-2012, 11:16 PM
i just found a gear ratio calculato and to get 10.083 i need a 10t out and a 55t on the axel
Old 11-27-2012, 11:22 PM
thats about the highest geat ratio it should pull stock with the governor you will never see 50MPH without it you should be able to do it but the rest of the bike is going to need extensive modification wheels bearings tires forks the stronest frame you can find its not a cheap build alot of the guys have $1500-2000 in there 212cc bikes
Old 11-27-2012, 11:24 PM
ok how fast can i go with the set up we have just established with the governor?
MotorBicycling.com
