Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with your 2 stroke engine? Just ask Norm, he loves to tinker and troubleshoot engines
Old 01-03-2010, 01:47 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: different way to mount a tuned pipe
the piston was reversed. I haven't looked at this for quite some time.
Old 01-03-2010, 03:35 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
hey Pappy, i stole the idea from Norman and ran with it. you can check out my results here:http://motorbicycling.com/f38/backwa...son-13458.html
i've got a few hundred miles on it so far, and i'm lovin' it this way. if you got any questions, feel free to ask...
Old 01-03-2010, 05:24 PM
FileStyle's Avatar
why would the piston need turned also?
FileStyleCycles
Old 01-03-2010, 07:13 PM
bairdco's Avatar
the gap on the rings can hang up on your intake port when you switch it. it might not. but it looked too close for comfort for me, so i reversed it. it's easy enough to do it while the rest of it's apart, so it's no big deal.
Old 02-14-2010, 11:59 AM
Norman's Avatar
Default Re: first time for this backwards top end
I changed the piston with the cylinder mainly to keep the piston and cylinder wearing the same areas.
I have found these engines with the rings locater pins facing the front of the cylinder and with them facing the back of the cylinder.
If your going to change yours check the cylinder and piston make sure that the ring gap does not go over a port or you stand a very good chance of hanging a ring on a port, it will break the ring making for a very sad day for you.
Old 12-12-2012, 12:29 PM
Deiseldave's Avatar
Deiseldave Deiseldave is offline
That looks more natural .... how many mods need to be made on the ports, is it difficult?
Old 12-12-2012, 01:54 PM
Norman's Avatar
Just a dremel to blend the ports, a torque wrench for the bolts, some gasket material, and assorted hand tools.
You will also need a modified exhaust pipe, and a modified intake manifold.
You can turn the cylinder around and leave the ports alone just to see if you really want to do the change.
I ran mine backwards for a while then went back to the original set up, I just wanted to say I was the first to do it.
Old 12-13-2012, 11:18 AM
bairdco's Avatar
thanks for talking me through it all those years ago, norman!
MotorBicycling.com
