Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Intake & Exhaust
Intake & Exhaust The ins and outs - carburetors, manifolds, mufflers, expansion chambers and more to keep your engine running the way you like
Old 12-31-2014, 11:08 AM
boxcar's Avatar
boxcar boxcar is offline
Default Re: Drilling into muffler cup
This seems funny to me.
((((I don't mean to offend any one here))))
I spent an entire day building a pipe that ran significantly quieter while adding a small amount of climbing ability to the bike.
It did restrict the top end a bit but i figured that if I want to go faster than 30 mph I'd ride my Bobber.
The whole reason ( for me ) that I built and ride a motorized bicycle is for the smile factor .
The ones on my face and the ones on just about every person I meet while riding the machine.
And I just love to build unusual toys.
But it was surly not for the speed .
If you feel the need for speed, and you are building a motorized bicycle to satisfy that need.
You have brought a knife to a gun fight....
I will admit that search for more efficiency and reliability have led me to alter the engine.
I have added a Delorto clone , I have an expansion chamber that I will run if I can quiet it down properly with a silencer, and am in the midst of some minor porting of the intake , exhaust and cylinder.
So far I have noticed some very small gains.
And am very excited about them.
Speed wasn't one of them.
I share the belief that if we garner to much attention by making loud and annoying machines just to gain a few mph. We will be regulated out of existence.....
The beauty of these machines is in there simplicity and efficiency, not there speed or raw power...... That's my rant for the day....
Happy trails all....
Old 06-26-2015, 04:50 PM
Hoopermotorbikes Hoopermotorbikes is offline
I have played around with modifying the exhaust system on the stock China girl. The best thing I every did was cut it open, take the some what of a cat out of it take me out original baffle out of it make one with bigger holes take the original exhaust cap ,drill the one hole bigger weld a bigger size pipe that comes out not to far and there you go its a tad bit louder put the perfomace gains are better. You will also need to up jet or change c clip down one as it will run a little leaner this all can be achieved by a ****y welder ,grinder, and sheet metal. Good luck.
Old 06-27-2015, 05:03 PM
Tony01's Avatar
Tony01 Tony01 is offline
I don't have a CG but I do have a 4-stroke. I can tell you from my rc car 2-stroke days, removing the stock muffler did make it more powerful, but then I added a tuned pipe and got almost double the power with less noise. A 2-stroke relies on exhaust back pressure to keep the intake charge in the cylinder, because both intake and exhaust ports are open at the same time. Without back pressure you will have to burn way more gas to get the same power.
On my bike, which is a 4-stroke, removing the muffler and putting a straight pipe was the difference between being able, and not being able, to do burnouts on pavement. I had to richen the mixture significantly but it sure has a lot more power. And it is far louder. When I punch it it will make bystanders jump.
My plan is to put a more powerful engine (think double hp) and run it with the quietest muffler I can find.
Old 06-27-2015, 11:58 PM
Davezilla's Avatar
The easiest way to quiet a 2 stroke and still run a very free flowing exhaust is by capping off the end and running a side bleed off the belly section of the expansion chamber, this will usually cut the noise by more than half, then use a moto cross silencer and it should run as quiet as stock if not quieter. The biggest drawback to a side bleed pipe is making it all fit the bike and still look good...
Old 06-28-2015, 12:05 AM
Davezilla's Avatar
That's a nice looking bobber... haven't seen an SU carb on one in a long time... was thinking about the same carb for my sportster but I ended up getting a 36mm Edelbrock performer carb for it instead. I like it but they discontinued it several years ago and it's hard to find the right jetting rods for it so I may need to switch to a 45 or 48mm mikuni when I put the Buell firebolt heads and a thunderheader on it as I don't think that little 36mm Edelbrock will feed it enough after those upgrades. A well tuned SU would work and look really well too if I can find one...
Old 07-25-2015, 05:07 AM
LongboardMalinois's Avatar
LongboardMalinois LongboardMalinois is offline
Today i took the end cap off my muffler to clean out all the oil, and i took it for a quick run to see what it sounded like, and i was definitely feeling an increase in torque and the engine just generally ran much better. I am wondering if this has negative effects on the engine, but i have an expansion chamber in the mail so would it be alright to do this every now and then, or will it immediately hurt my engine? It is ear-ringing loud, but it really doesnt matter because i live far away from any major road or any houses.
Old 07-25-2015, 08:52 PM
Davezilla's Avatar
It won't hurt your engine as long as you got some kind of a pipe on there... what can hurt it is running no pipe at all or a really short pipe...
As far as noise is concerned, drilling extra holes in the end cap will be considerably quieter than riding without it installed but will offer up some decent performance.
MotorBicycling.com
